I’ve been reading through discussions here and I’m curious which practical habits other engineers rely on once composite simulations move from coursework or quick studies into real design decisions. Here are the ones that have helped me most so far:
- Validate material data first. Checking ply properties against test data saves a lot of confusion later.
- Start with a coarse mesh. A quick first run shows where refinement actually matters.
- Document the layup clearly. A simple table of plies, angles and thicknesses avoids costly mix-ups.
- Check results against hand calculations. Simple laminate theory is a great sanity check for big models.
- Model manufacturing effects early. Residual stresses and fibre misalignment can change results more than expected.
- Keep versions of every run. Clear naming makes it easy to compare design changes side by side.
- Share assumptions with the team. Writing down boundary conditions and limits builds trust in the results.
Which habit made the biggest difference for you when modeling composites? I’d love to hear what worked, and what you’d do differently next time.
