TRI6 elements written with midside node in N4 slot, causing VABS Jacobian error
PreVABS 1.6.0 · .sg output
Description
For meshes containing higher-order triangles (TRI6), PreVABS writes the first midside node into the N4 column instead of N5. Per VABS manual, N4 must be zero for triangles. VABS interprets the misplaced node as a degenerate quad corner and aborts:
Something wrong with the mesh. The Jacobian of element 1 is less than zero.
Expected vs actual
Expected:  ElemID  N1     N2     N3     0   N5mid  N6mid  N7mid  0  0
Actual:    ElemID  N1     N2     N3     N4mid  0   N5mid  N6mid  0  0
Workaround
Swap N4 and N5 for all triangular elements in the generated .sg file. Confirmed to resolve the Jacobian error.
Environment
Thank you for reporting this issue. This will be fixed in the next version.
I’m pleased to report I did not encounter this issue with PreVABS 2!
