PreVABS 2.0 is Now Available
A major update aimed at improving stability and user experience.
v2.0.1
  • Fixed a value issue in the global material database
  • Fixed some issues in the documentation
v2.0.0
Highlights:
  • Improved geometry computation robustness
  • Informative warnings and error messages
  • More consistent cli arguments syntax
  • Support for quadrilateral elements
Get started
Thanks Su! What’s the difference between prevabs-v2.0.0-windows-x64-full and prevabs-v2.0.0-windows-x64? Should we use one or the other?
The one with “full” includes gmsh.exe in it. If you have already installed gmsh on your machine, then you can use the other package.
Thank you. Also FYI I just tried running some examples, I could be wrong but I think there’s an issue in the MaterialDB.xml file, at line 1498
  <zt>e3</zt> <!--Approximate -->
PS C:\Users\dana.frye\Documents\VABS\vabs_2_test\prevabs2> prevabs -i X1310.0.xml --hm -v
[info] PreVABS 2.0.0 (VABS 4.0, SwiftComp 2.1)
[info] prevabs start (2026-05-05 19:10:02)
[info] reading input files
[info] reading main input file: X1310.0.xml
[info] reading airfoil data file: airfoil.dat
[info] reading materials file: C:\Program Files (x86)\preVABS\v2.0.0\MaterialDB.xml
[warning] material ‘jts98-nickle’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘3K70P/NB321 fabric’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘3G150 NASS/NCT321’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘S2/SP381’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T650 3K-70-PW/7740 Fabric’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘G30-500 12K/7740’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T300 3KPW/E765’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T700 24KP/E765’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T300 6K 5HS/E765’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T700GC-12K-31E’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘HITEX 33 6k/E7K8’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘AS4 12k/E7K8’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘Celion 3000/E7K8 fabric’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘HITEX 33 6k/E7K8 fabric’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘GY-70/934’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘E-Glass 7781/EA 9396’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T650-35 12k/976’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘S2-449 43k/SP381’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘7781/EA9396 fabric’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘Celion 12k/938’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘AS4 12k/3502’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T300 15k/976’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘AS4 6k/PR 500_fabric’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T300 3k/EA 9396_fabric’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[warning] material ‘T650-35 3k 976_fabric’: not specified, using default 0.3; provide nu23 explicitly for accuracy
[error] homogenization failed: Invalid numeric value ‘e3’ in /
When I changed the e3 to a value example run successfully
