Need advice on our Abaqus Hydrualic fracturing project
We are doing a project that focusses on hydraulic fracturing in wellbore, that is basically done to increase the production.
For that,
  1. We have created a 60 x 60 2D block (we are trying to simulate in 2D plane strain condition)
  2. We have created a partition in the middle of the block to incorporate zero thickness cohesive zone.
  3. Given the properties of matrix and that of the cohesive zone (We first assigned the partition as a cohesive layer in the mesh module)
    Matrix:
    (i) Elastic- Isotropic
    Young’s Modulus: 627MPa
    Poisson’s ratio: 0.31
    (ii) Fluid Leakoff
    Top Coeff. = Bottom Coeff. = 1.786 * 10^-13
    (iii) Permeability
    k= 1.24 * 10^-15 m^2 (1.24 mD)
    Void Ratio= 0.3245
    Cohesive:
    (i) Elastic- Traction
    E/Enn = G1/Ess = G2/Ett = 100
    (ii) Maxs Damage
    Nominal Stress Normal Only Mode= 1.16*10^6 (tensile strength= 1.16MPa)
    Nominal Stress First Direction= 2.32*10^6 (shear strength= 2.32MPa)
    Nominal Stress Second Direction= 2.32*10^6
    (iii) Damage Evolution
    Displacement at failure= 0.0001m
    (iv) Fluid Leakoff
  4. Created a “Soils” step with a time period of 75s.
  5. In the load module:
    (i) One predefined field was void ratio
    (ii) Other was stress to simulate in-situ stresses ( x and y direction 3Mpa compressive)
    Sigma 11= Sigma 22= -3e+06
    Sigma 33= Sigma 12=0
    (iii) Load (flow rate) was applied in Step-1 in the center point (concentrated pore fluid with magnitude = 5*10^-4 m3/s)
    (iv) Boundary conditions were also applied:
    a) U1=0 ( for the extreme two bottom corners)
    b) U2=0 (for lower edge)
  6. Coarse mesh was used.
  7. After evaluating job, we are getting following results:
We are not able to induce a crack as it should be in hydraulic fracturing.
What do you guys think can the reason for it be?
We are trying to replicate this:
