Discrepancy Between SwiftComp 2D and 3D Homogenization for Thin Plain-Weave Composites
Hello everyone,
I’ve been investigating a discrepancy between the in-plane Young’s modulus (E_1) obtained from SwiftComp 2D (Kirchhoff–Love plate) and 3D homogenization.
For a single-ply plain-weave laminate, the results differ by approximately 16%:
  • 3D SwiftComp: (E_1 = 81.86) GPa
  • 2D SwiftComp: (E_1 = 68.70) GPa
Using the 3D engineering constants, I calculated the bending stiffness using classical laminate theory:
[D_{11}=\frac{E_1t^3}{12(1-\nu_{12}\nu_{21})}]
For a thickness of 0.0667 mm, this gives approximately 2.03 N·mm, which is close to the 2.17 N·mm obtained from an independent FEM analysis.
However, the 2D SwiftComp homogenization predicts (D_{11}=0.55) N·mm, which is significantly lower.
Interestingly, as I increase the number of plies, the 2D and 3D predictions begin to converge. The 2D in-plane modulus (E_1) approaches the 3D value, and the bending stiffness (D_{11}) from the 2D analysis approaches the FEM results.
Has anyone encountered similar discrepancies when homogenizing thin plain-weave composites using SwiftComp? Is this expected behavior due to the different homogenization assumptions, or could there be an issue with my model setup?
Any insights would be appreciated.
Thank you!
Can you provide more details about your model? are the E1 directly output from SwiftComp for both 3D solid model and 2D plate model? Are the results converged? If you provide more model details, one of my students can help you verify. @Yu_Group
after looking at your files, your results make sense. When you use a 2D plate model, it will directly compute ABD matrices, then back calculate in-plane properties and flexural properties. The results will be different from 3D model. The reason is that when you use 3D model, the plain wave SG is actually constrained all three dimensions. However, when you use 2D plate model, the SG is only constrained in the in-plane directions, and it is free in the third direction. Thus, the properties will be different from 3D results. Once you have more layers, then only top and bottom surfaces are free and other surfaces are constrained, which is why it is approaching 3D results.
Thank you for the explanation. I understand your point. I suspected that the boundary conditions are responsible for the difference in the in-plane properties.
However, I’m still unsure why my Abaqus FEM bending simulation does not agree with the (D_{11}) value obtained from SwiftComp. The FEM model uses a simple bending setup with reference points and coupling constraints, without periodic boundary conditions.
Could the boundary conditions in the FEM model explain this discrepancy? I wouldn’t have expected them to cause a difference of approximately four times. Again, the FEM model results and SwiftComp 2D results are similar when increasing the plies (about 3 plies).
@AKSHAT_BAGLA can you help this user to figure the problem? You can use both SwiftComp and OpenSG, which is another validation example for you.
Hey @AKSHAT_BAGLA. Can you let me know how I can get in touch with you? I’m happy to communicate in the thread but I cannot seem to attach any files for your reference.
Hello @myapa2
Greetings. We can continue communicating through this thread. For the files, it would be great to have the input files. Can you please share them through google drive or mail me at bagla0@purdue.edu (either way works for me)?
I can run the simulation using SwiftComp/OpenSG to resolve the issue that you are facing.
@CompositesAI @myapa2
We checked this on a similar thin plain-weave SG, using the same heterogeneous tow/matrix mesh in both the plate homogenization and Abaqus. For a true single fabric layer, every Abaqus model reproduced the low plate D₁₁:
  • periodic pure bending matched it within about 1 %;
  • a coupon with the end faces coupled to reference points, like yours, matched it within 0–2 %.
None of these models came close to the CLT value; they all gave about 0.4 of it.
Your Abaqus result, 2.17 N·mm, is almost exactly the CLT value (2.03 N·mm). This suggests your Abaqus model is not solving the same problem as the SwiftComp single-layer plate SG. Most likely it uses homogenized 3-D properties instead of separate tows and matrix. A second possibility is that the “single-ply” SG is not a true single fabric layer, or that the thickness differs between the models. The SG we started from looked like one ply but contained two.
One check would settle it: run a periodic pure-bending Abaqus model on the exact SG you used in SwiftComp 2-D, with free top and bottom faces.
  • If it gives a low D₁₁, near 0.55 N·mm, your coupon model is the cause.
  • If it gives a high D₁₁, near 2.0–2.2 N·mm, the SG or thickness definition is the cause.
The agreement at about three plies is expected: the effect of the free top and bottom faces of a single crimped ply fades as more plies are stacked.
@bagla0 Thanks for the response. What you are describing is what I would have expected for the D11 from the Abaqus analysis as well. And when the coupons get thicker it should approach CLT which I’m seeing from the SwiftComp anslysis.
I’m using the same model from TexGen for both the SwiftComp and Abaqus analysis. So it’s a tow homogenized with matrix mesh.
I am not applying periodic boundary conditions but I think it should be close enough given there’s no coupling between bending and extension. I’m also not restricting the transverse direction since D12 is very small and the deformed shape doesn’t show noticeable transverse curvature on the transverse edges even after deformation magnification. I expected this simulation to be in the ballpark of the SwiftComp but it’s not. I would appreciate it if you can take a look at the models and see if I’m setting something up incorrectly. The files are in the link below. Content: Swiftcomp analysis files, abaqus input file, Texgen raw mesh.
Thanks.
@myapa2 @Wenbin
Thanks for sharing the files. We checked them carefully and were able to reproduce all three of your original numbers on the exact same TexGen mesh, materials, and yarn orientations: Abaqus coupon D11 = 2.182 N mm, SwiftComp plate D11 = 0.550 N mm, and SwiftComp 3-D E1 = 81.86 GPa. The good news is that your boundary conditions are not the problem: the end-face couplings are set up correctly, the reference points are on the mid-plane at the face centroids, and the model is not over-constrained. The main issue is the element type and through-thickness resolution in the Abaqus model: it uses linear tetrahedra (C3D4) with only about two effective layers through the 0.0667 mm ply, and that mesh locks badly in bending.
When we changed only the Abaqus element type from C3D4 to C3D10 on the same mesh, D11 dropped to 0.769 N mm. Refining that quadratic mesh through the thickness changed it only slightly, to 0.764 N mm, and a periodic pure-bending cell with C3D10 gave 0.740 N mm. That means your coupon setup without periodic BCs and without transverse restraint is actually quite close once the bending-locking problem is removed. We also ran SwiftComp with quadratic tets on the same mesh, and it gave 0.740 N mm, matching the periodic Abaqus C3D10 result to five digits.
CompositesAI chat
This chat holds, in order:
  • the analysis plan made after the input files were read;
  • the verdict on the five planned runs;
  • the question about why linear tets came out softer than quadratic ones, and CompositesAI’s switch to the periodic C3D4 check;
  • the final verdict: C3D4 locking is the bug, and D11 is about 0.74 N·mm;
  • its plan for why SwiftComp’s linear-tet value is low;
  • the forum reply
The shareable files for Abaqus can be found in share_cdmhub_user - Google Drive used for the analysis.
Along with checking your files, we ran an independent study to test whether the low single-ply plate D11 is a real effect. We used a published thin plain-weave SG (the 0.04 mm plain weave of Rouf, Liu and Yu) and built the same tow/matrix mesh in both the MSG plate homogenization and Abaqus. The report is attached: “Resolving the single-ply woven plate bending mismatch”.
Main points:
The single-layer plate D11 is low. It is about 0.40 of the CLT value built from the 3-D constants, while E1 is 0.845 of the 3-D value.
Abaqus reproduces it with a fine enough mesh. We used hexahedral C3D8/C3D8I elements, 8 through the thickness. The model matched the plate D11 within about 1–2 % under all three set-ups tried:
-periodic pure bending;
-free-edge traction coupons;
-coupons with the end faces coupled to reference points.
The coupling itself changed D11 by only 0–2 %.
Stacking closes the gap. D11/CLT is 0.87 with 2 layers and about 1.0 with 6 layers, which fits what you see at about three plies.
So a single-ply D11 well below CLT is a real effect of one crimped layer with free top and bottom faces. An FE bending model reproduces it once the elements through the thickness can carry bending. That is the same issue we found in your C3D4 model.
thin_plain_weave_plate_vs_solid.pdf (2.2 MB)
@bagla0, Thanks a lot for the detailed explanation! I oddly missed the fact that I was using linear elements. An obvious mistake on my part. I suppose how SwiftComp solves for constitutive behavior is quite different from how the traditional FEM works.
The through thickness mesh refinement from TexGen is unfortunately not an option for volume mesh. Are you using voxel mesh for that model?
When using tet10 in SwiftComp I see that the stiffness has increased compared to tet4. This is the opposite of what happens in traditional shear locking in FEM. What is the reason for this considering how SwiftComp works? Do you recommend using quadratic meshes in SwiftComp whether it’s a volume mesh or a voxel mesh?
Thanks again for the detailed report.
Yes, for your model we did not remesh in TexGen. We kept your exact tet mesh and only changed the element order, first to tet10, and then in one separate check we split each tet into 8 outside TexGen. In our other plain-weave study, we did use a voxel hex mesh with about 8 elements through the layer thickness, and there the Abaqus bending results matched the plate homogenization within about 1–2%.
On why tet10 is higher than tet4 in SwiftComp: In SwiftComp plate homogenization, the linear tet4 plate solution on this thin mesh is too compliant in bending, not too stiff. Even for a simple homogeneous plate on the same mesh, tet4 underestimates D11 by about 10.4%, while tet10 is essentially exact. For your woven ply, the same effect is amplified by the heterogeneity, so tet4 gives 0.550 while tet10 gives 0.740. That is different from standard 3D FEM bending with linear tets, where the same mesh locks and becomes too stiff.
So yes, for SwiftComp I would recommend quadratic elements whenever you use an unstructured volume tet mesh for thin plate bending. For voxel-style hex meshes with enough elements through the thickness, first-order elements can work well, but for thin unstructured tet meshes the safer choice is quadratic elements, especially if D-matrix terms are important.
Sounds good! Thank you for helping me sort this out.
