Batch cross-sectional analysis of 1600+ airfoils with PreVABS + VABS
A simple example that walks through running PreVABS/VABS in batch mode to compute Timoshenko beam properties across a large set of airfoil cross-sections — useful if you’re doing parametric or trade studies on composite slender structures (blades, wings, etc.).
What it covers:
  • Starting from standard Selig-format airfoil coordinate files (UIUC database)
  • Reusing a single PreVABS XML template across different materials and layup configurations (aluminum skin, CFRP at 0° and 45°)
  • Post-processing VABS output with sgio to extract a configurable list of section properties (mu, ea, gj, ei22, ei33, coupling terms, etc.) into a flat CSV
  • An interactive plot (dropdowns for x/y properties, airfoil highlighting, toggleable legend) to browse results across all 1600+ cases
Config is JSON-based, with concurrency control, sampling, and a continue/stop failure policy for batch runs.
The shared template only exposes a handful of placeholders (airfoil geometry, LE/TE points, material, layup), so the same batch-driver pattern extends readily to other cross-sectional designs — see the PreVABS documentation for the full set of supported geometry and layup options.
Full example, source code, and the interactive plot:
It would be interesting to build a surrogate out of this.
A Large cross-sectional model?
a large cross-sectional model?
Yes. I can think of two approaches. The mesh/point cloud based surrogate. or the text input based surrogate – fine tuning an existing LLM, attach an intermediate layer to a numerical output layer.
@su.tian.22 do these ideas make sense?
